Toggle Content Welcome Guest! Please Register or Login Tue June 19, 2018, 6:54 am
AZBMW Forums › Model Specific Discussion › ///M Cars › help with SAP delete
azdakarm3
PostPosted: Fri Dec 05, 2014 10:18 pm
Post subject: help with SAP delete
Hey everyone, kinda stuck on this SAP delete and hopefully you guys can help! I bought the plug & play kit from e36-electronic.com, everything plugs in just fine but I'm still throwing a P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction.
I removed the pump, air control valve etc, and I plugged one side of the vacuum control module (below). I rechecked all the connectors from the sim, made sure there were no vacuum leaks and am still stuck. Any help would be greatly appreciated!
JimsR
PostPosted: Sat Dec 06, 2014 1:42 pm
Post subject: Re: help with SAP delete
What do you have connected to the electrical connection on #7. I believe that should still be connected to the original wire harness.
She's built like a steakhouse but handles like a bistro
laplana325i
PostPosted: Sat Dec 06, 2014 6:35 pm
yes you should connect the #7 back.
azdakarm3
PostPosted: Sat Dec 06, 2014 6:48 pm
Thanks for the reply guys, #7 is still connected to the harness by the fuel injectors. I only capped #9 since it wasn't needed. Could it just be I need a new vacuum control valve (#7) ?.
laplana325i
PostPosted: Mon Dec 08, 2014 9:18 pm
that control valve rarely goes bad.
