Toggle Content Welcome Guest! Please Register or Login Mon July 16, 2018, 7:52 pm
AZBMW Forums › General Forums › General Discussion › E30 rear driver suspension or wtf?!
Community discussions
Post new topic    Reply to topic    Printer Friendly Page     Forum Index ›  General Discussion
Tfizzle
PostPosted: Sat Nov 22, 2014 9:12 pm
Post subject: E30 rear driver suspension or wtf?!
So this metal clanking noise has started happening on my car right now. I have no idea wtf it is. I just replaced the wheel bearing a few weeks ago. It sounds like complete shit. I took the wheel off everything is intact and tightened!
So now I'm just lost. Any insight would be greatly appreciated.
johnlemonx
PostPosted: Sat Nov 22, 2014 11:49 pm
Post subject: Re: E30 rear driver suspension or wtf?!
When does it happen? Does it only happen when the car is moving? When it's stopped and revving? When braking, decelerating, acceleration?
Check the cv joints, exhaust system, center support bearing, check for play in the drive shaft. Could be a loose heat shield.
1989 525i 193k bronzitbeige metallic
1993 325is Brilliantrot
wannabM
PostPosted: Mon Nov 24, 2014 2:11 pm
Could be rear subframe bushings... but most likely bad u-joints. I have new poly rear sub frame bushings for sale. And a fresh driveline.. if your car is automatic m20
...it can take the abuse...
laplana325i
PostPosted: Mon Nov 24, 2014 3:50 pm
I also have full rear suspension parts, if you end up needing any
Tfizzle
PostPosted: Mon Nov 24, 2014 9:53 pm
Its my wheel bearing again! i have no idea why it keeps going out. 3rd time this year though. got it changed out maybe i need a new hub assembly and look into a rear bushing set they are pretty thrashed and could use some poly-urethane upgrades!
Tfizzle
PostPosted: Mon Nov 24, 2014 9:54 pm
i will keep you in mind!
