Toggle Content Welcome Guest! Please Register or Login Thu May 24, 2018, 10:16 am
AZBMW Forums › Model Specific Discussion › Other Models › C5 Corvette Z06
C5 Corvette Z06
Everything non BMW
Post new topic    Reply to topic    Printer Friendly Page     Forum Index ›  Other Models
PostPosted: Thu Mar 20, 2014 12:55 pm
Post subject: C5 Corvette Z06
In November I flew out to Sacramento to pick up this Black on Black 2002 C5 Z06 with 22,000 miles on it. It was a long drive back but I crossed the upper California desert and got to drive some truly amazing mountain roads in a new to me vehicle with 625bhp and 8 year old tires mounted backwards. It was a fun and slightly puckering experience.
I bought the car to drive and track, and that is exactly what I have done so far. I've placed roughly 3k miles and two HPDE weekends on it in the past few months. The car is an absolute blast to drive.
The car comes heavily modified from the original owner having a blower cam, upgraded valve springs and hardened pushrods installed to support the ProCharger blower kit. In addition the transmission has also been built to support the 535whp and 475wtq. The car also has fully adjustable coil overs. I felt it needed a few things addressed so I purchased non chromed OE C5z wheels, +1 size Nitto NT05's, installed poly suspension bushings front and rear and installed a Wilwood SL6R big brake kit up front.
I must say, driving this car is an absolute blast. Power is on tap at all times and it handles very well and gives amazing feedback. All in all, this ranks towards the top as one of the top five cars I've ever owned.
A few laps from a recent track day
Details:
EXTERIOR:
HID 6000K Bulb kit with slim ballast design
Tint 15% rear, 35% sides
INTERIOR:
Hurst Short Shifter with Delrin 3” knob
IPod 30-pin Dock Connector
Lloyd's Black Ultimats “Corvette Racing”
“Z06” Partition Divider
Autometer Cobalt Gauges w Pillar Pod (Fuel Pressure, Boost/Vacuum)
ENGINE:
Procharger P1SC1 w/ Twin 4.5” Intercoolers
Remote SC Drain Line
FAST 92mm Intake
LS7 Throttle Body
Custom Ground Blower Cam 222/226 (Mild)
Hardened Pushrods
Titanium Springs
Double Roller Timing Chain w/ Hardened bolts
60lb Injectors
Kenne Bell Boost-a-Pump
NX Inline Fuel Adaptor for Fuel Pressure Sensor
MSD Plug Wires
NGK Spark Plugs
Optima Red Top Battery
Dyno Tuned by Force Fed Performance Sacramento, CA
EXHAUST:
Kooks Long Tube Headers
Kooks X-pipe w/ High Flow Cats
SLP Powerflow Quad Tip Exhaust
TRANSMISSION:
RPS billet twin with steel flywheel
RPM Level V 6 speed transmission
Remote Clutch Bleed Line
SUSPENSION/Brakes:
LG G2 Coilovers
VB&P Poly Control Arm Bushings
OEM Speedline Wheels
Nitto NT05 275/40/17 and 295/35/18
Wilwood SL6R Front Brake Kit w/ Floating 13.06” Slotted Rotors
Motul 600 Brake Fluid
Stainless Steel Brake Lines F/R
Alignment Specs;
Front Camber 1.35, Caster 6.5, Toe 0
Rear Camber 0.94, Toe 1/16” (1/32 total)
PostPosted: Thu Mar 20, 2014 5:44 pm
Post subject: Re: C5 Corvette Z06
love this picture!! so how was it on the track compared to the s50 car? As far as cornering and what not, not really straights as i know that answer lol
i watched that video and looks like you had some fun!
fix the SC belt?
PostPosted: Thu Mar 20, 2014 5:58 pm
fix the SC belt?
Thanks Austin!
Really isn't much of a comparison. The E30 would let you drive it harder and was surprisingly forgiving in retrospect. The Z06 is a lunatic that has to babied out of all the corners as the throttle response is crisp, power delivery is quick and even with warmed up 295's that rear end will swing right around.
I will continue to work on being faster in the turns. Straight line stuff is silly. The builder says it should be a 10sec car no problem.
Belt was an easy fix. Note to self, keep an extra belt and a 13mm box wrench available at all times Wink
M3_Dust
He's Angry!
PostPosted: Thu Mar 20, 2014 7:30 pm
dhahlen
PostPosted: Fri Mar 21, 2014 1:05 am
Grow out that mullet! Have to love the sub 500ftlbs
View user's profile Visit poster's website ICQ Number AIM Address MSN Messenger Yahoo Messenger
PostPosted: Fri Mar 21, 2014 1:44 am
Haha do ittt
There's a guy a few houses away with 3 identical Corvettes. You guys can be friends!
bonehead
PostPosted: Fri Mar 21, 2014 1:52 am
I can't believe you aren't going to the Shift S3ctor event next month....smh
nasrudin
Has SennaVision
PostPosted: Fri Mar 21, 2014 1:58 am
What a nice neighborhood.
