Toggle Content Welcome Guest! Please Register or Login Fri June 22, 2018, 9:13 pm
AZBMW Forums › Model Specific Discussion › 1-4 Series › F my rear axles...
F my rear axles...
Cheerios
PostPosted: Sun Feb 02, 2014 10:40 pm
Post subject: F my rear axles...
I need to replace my rear axles on my 94 325i and I can't get this huge 30mm 12 point to budge...I tried someone on the brakes, tried on the ground, PBblaster, whack'n the socket while on the nut, whack'n the hub surrounding the nut, a breaker bar almost 2.5' long....nothin....I hear you can roast the nut and axle with a torch of some sort, but I also hear that ruins your bearings, which I'm not trying to replace at this time...besides replacing the entire control arm and hub assembly, what might my next move be?
-Cheerios
S52limo
PostPosted: Mon Feb 03, 2014 1:18 am
Post subject: Re: F my rear axles...
Did you bend back where it was pinned over to lock on the axle?
Cheerios
PostPosted: Mon Feb 03, 2014 8:27 am
Yes.
-Cheerios
Cheerios
PostPosted: Mon Feb 03, 2014 9:18 am
Okay F my rear axles, open diff vs. lsd, are the internal splines the same on both? If I could swap my output flanges then I could just leave my axles alone.
I'm going from an m3 lsd, to a open diff.
-Cheerios
waygone
PostPosted: Mon Feb 03, 2014 3:43 pm
yes i swapped out my none lsd cover and flanges for my lsd one.
Cheerios
PostPosted: Mon Feb 03, 2014 8:59 pm
My dumb ass sold my lsd...
The lsd was a 3.18(I believe) from a m3 (unsure of the year) so the axles (that don't fit my open diff) must also be m3/lsd...
Does anyone know the correct diff/flanges that i need?
-Cheerios
