Toggle Content Welcome Guest! Please Register or Login Tue June 19, 2018, 6:35 am
AZBMW Forums › Model Specific Discussion › ///M Cars › DME issues (OBDII E36 M3)
The_Driver
PostPosted: Thu Apr 04, 2013 4:21 pm
Post subject: DME issues (OBDII E36 M3)
Does anyone in AZ have DIS/INPA and an ADS interface?
I swapped a 98 M3 engine into a 96 318 and I need to copy/paste (sync) the rolling code from the EWS into the DME so they will talk and my car will start.
TRM will delete EWS from the DME for $100.00 if I can't find someone locally with the software and wire.
Also, I saw that there is a Conforti shark device to flash this DME. Does anyone have this?
Thanks!
ti_kid
PostPosted: Fri Apr 05, 2013 3:23 am
Post subject: Re: DME issues (OBDII E36 M3)
you didnt grab the ews module and chip from the key when you got the motor from donor car? we juat did this swap into a buddies e36 and grabbed the listed parts and everything works fine
BK544E34
PostPosted: Fri Apr 05, 2013 9:41 am
What ti_kid said. If you have the EWS module and it matches the DME and key, you should be good. I'm making the assumption that you didn't.
I believe Conforti Shark is mated to the car. IE. One car use only.
[1994 544i][1999 Z3 M Coupe][MK3 VR6 Jetta]
Enjoying the not-so-120 degree summer!
