Toggle Content Welcome Guest! Please Register or Login Tue June 19, 2018, 6:16 am
AZBMW Forums › Model Specific Discussion › 1-4 Series › E30 DOHC Swap Rough Idle
Kaimer
PostPosted: Mon Apr 01, 2013 3:56 pm
Post subject: E30 DOHC Swap Rough Idle
Hey AZBMW
So, I have a 1985 318i, with an M50 swap from a 92 325is. Just curios if anyone has any pointers of what else to check, any help is greatly appreciated!
The Problem Evil or Very Mad : The car starts up and runs fine, however...After about 2-3 minutes of sitting at idle the motor starts to have a rough idle, never tries to stall out, just a rouch up/down rpm curve.
I already cleaned the throttle body, and ICV and everything is clean and seems to be functioning fine...
Any ideas of what else it could be?
finnishkid
PostPosted: Mon Apr 01, 2013 6:05 pm
Post subject: Re: E30 DOHC Swap Rough Idle
vacuum leak
S52limo
PostPosted: Mon Apr 01, 2013 9:01 pm
finnishkid wrote:
vacuum leak
This
Kaimer
PostPosted: Mon Apr 01, 2013 10:10 pm
Ahhaa!
*I hate to be that guy*
But this is my first project car...and well Any suggestions on how to test where the vacuum leak may be? or maybe points of orgin that are common? *Sorry if thats a dumb question*
I really apprecaite the two replies though Smile
PostPosted: Tue Apr 02, 2013 1:44 am
Get starter fluid and a spray can straw. Combine that and use in suspected areas of the intake system. In case of a vacuum leak you will hear a change in the idle when spraying. Be sure to check where the manifold meets the head and the lines to the brake booster.
S52limo
PostPosted: Tue Apr 02, 2013 1:59 pm
The intake boot is commonly the culprit.
