Toggle Content Welcome Guest! Please Register or Login Sat June 23, 2018, 10:17 am
AZBMW Forums › Model Specific Discussion › 1-4 Series › A Simple Four Door.
A Simple Four Door.
waygone
PostPosted: Tue Feb 19, 2013 2:48 am
Post subject: A Simple Four Door.
So I picked up a BMW again.
Specs
1988 325e manual 250xxxmiles!!!
No big plans for the car just daily status ASAP.Lower it and clean it up.
I've started to do lots of the basic maintaince that it needs badly.
J-B welded vacuum nipple back into TB, Fuel filter, spark plug, new battery, new neg battery cable, New vacuum lines(FPR, vavlecover breather, hard asfcuk under the manifold/behind the TB to evap canister hose.)
Just did valve adjustment.
Need to do waiting on parts.
TIMING BELT. (will be here 2/21)
Water pump
Here's what everyone wants!! Pics!!
sterling
Is fassssst!
PostPosted: Tue Feb 19, 2013 3:27 pm
Post subject: Re: A Simple Four Door.
The humpdy dance, it's your chance, to do the HUMP!....
DO ME BABY!
Sorry. Sleep deprived. Nice car, Mike!
waygone
PostPosted: Fri Feb 22, 2013 2:27 am
Well i have been chasing a miss in cylinder #3 the last couple of days I have solved it... It was an injector stuck open.
Tonight I started to work on maintance work.
All the water hoses and pipes and thermostat cover/housing removed.  Will be pulling the fan and rad tomorrow night.  And then the intake manifold.  Then Fun with new parts timing belt and water pump , thermostat , water temp sensor, and a new INJECTOR.
waygone
PostPosted: Sat Feb 23, 2013 5:22 am
I pulled the thermostat housing and cover and crossover tube to work and washed them and sandblasted them.( on my break. Boss) I have now painted the crossover pipe with high temp paint.
I got more parts in today, thermostat , and some gaskets
I got home and started to pull the rad. And I forgot at ask my co worker to borrow his fan wrench so I was stuck. Then I decided to pull my injectors and rail. When i got my injectors out I found this...
Wicked clogged number 3 injector. Which is weird because my number 3 cylinder was sticking open. Maybe full of dirt.
Pulled my front grills my two inner lights have problems ones cracked and the other get full of moisture..
I will be tucking bumpers soon. And posting pics ASAP .
PostPosted: Sat Feb 23, 2013 12:26 pm
Wow, that injector is haggard!
waygone
PostPosted: Sat Feb 23, 2013 9:59 pm
So I had to clean my shop it was a pit.. So let paint dry when I Cleaned. Inners are to cracked out to save. Need to tuck bumpers tonight. Feels good having the shop cleaned up. Pics of the Frenchness..
waygone
PostPosted: Thu Feb 28, 2013 4:33 am
Installed new water pump , timing belt, sand blasted covers, new injectors and fuel rail!!!
Still need to get new fuel line for the rail. Some water hose and a barbed fitting to bypass the TB.
Tomorrow painting pulleys black again. finishing installing parts up front(pulleys, belts, fan, rad)
Clean up under intake and reinstall TB, new rotor & cap. And old wires. Fill fluids and start!!!!
Can't wait to be done with the motor work so I can get to suspenion.
waygone
PostPosted: Thu Mar 14, 2013 2:16 am
So I have finished up all the little things this weekend: Fuel hoses, TB coolant bypass, filling rad, Fan, pulleys, belt, TB, wires, new cap/rotor.
And tonight ingot two gallons of 91 and she fired right up. Had a little stubby idle. But it cleared right up.  I wanted to clean the motor so I added seafoam to the oil and gas. Then to the intake.. I love the smoke storm the plows out of cars when I do this.  She is idling like a champ now.  I think I'm done with motor stuff for now.
Hope I get new parts this weekend.
And swap good tires i have on to the front wheels.
Sorry no new pics
waygone
PostPosted: Mon Mar 18, 2013 2:32 am
Front.
Side
need to do a photo shoot tomorrow.
New painted black BMW bottle caps with new tires.
Kw springs
Bilstien sport front shocks
Soon new rear shocks
Next on the list ..Find the vibration in the car. I think it's the center support bearing.
Then will be a lip added to the front ( I have it all ready)
And tint, a/c will happen shortly.
waygone
PostPosted: Sun Mar 24, 2013 10:10 pm
 Then I added a lip.
I also rebuilt the full drive shaft last week. Unserviceable my ass.
On my way to pick up offset cabs an tierods with space tonight. More work for next weekend. E90 springhats will be ordered this week from work. And I think I'll be done with suspension for a while.
codyep3
PostPosted: Sun Apr 14, 2013 4:58 am
looking good broseph
waygone
PostPosted: Sun Apr 14, 2013 12:52 pm
Forgot ***I tucked the front bumper and drilled the rear still have to back up in to a wall or post to finish the tuck.
I picked up the black bottle cap with awesome tires when I got the suspension.
Yeah the interior is good but the seats! Looking for black leather or tan sport Seats.
Will be going through the steering system next Flushing/cleaning and looking for leaks.
Then A/C it's a must!
Then rear diff upgrade. Keeping 2.93 but with LSD. With new rear bushings all around.
waygone
PostPosted: Sun Apr 14, 2013 12:53 pm
Moar... Well I couldn't wait till the weekend I installed the new front contaol arms and offset cab's.  I didn't get to install the tie rods.  But I pulled the drivers side strut out and found the clunk at low speed u-turn I had.  Turns differently now I can't put my finger on it. And I fixed my shimmying under hard braking.  So a good night.  Pics. Sorry only one of the parts none of the install.
[img width=540 height=402]http://i107.photobucket.com/albums/m308/ikonwun/Mobile%20Uploads/IMG_2437_zps5f1c5b7f.jpg[/img]
It kick the front wheels just a hair forward in the wheelwell.
waygone
PostPosted: Sun Apr 14, 2013 12:54 pm
The car started to run like crap. I figured out it was the cat.. Stock exhaust had been hacked up and a cheap cat installed. So I found a nice ASNA exhaust and started to install it today.  More studs came out than nuts came off.  But nothing broke and wasn't it a huge pain in the rear.  I have to wait till Monday untill I can get studs and nuts and gaskets from work.  So I took out my die grinder and gasket matched the stock exhaust headers. I read a lot on the interwebs whether headers are worth it or not. So a good gasket match and sandblasting them then painting with  high temp paint. With be a good *cheap* alternative .. I can post pics if anyone wants.
waygone
PostPosted: Sun Apr 14, 2013 12:57 pm
[img width=540 height=723]http://i107.photobucket.com/albums/m308/ikonwun/Mobile%20Uploads/IMG_9380_zps464564df.jpg[/img]
Before
[img width=540 height=402]http://i107.photobucket.com/albums/m308/ikonwun/Mobile%20Uploads/IMG_1145_zps1dbc2dc9.jpg[/img]
After .the black soot line is thinner. Opened 3-5 mm.
[img width=540 height=402]http://i107.photobucket.com/albums/m308/ikonwun/Mobile%20Uploads/IMG_0367_zps9c3cc0cd.jpg[/img]
Before
[img width=540 height=402]http://i107.photobucket.com/albums/m308/ikonwun/Mobile%20Uploads/IMG_4414_zpsb9bcf40f.jpg[/img]
After soot line was thin 1-3mm
