Toggle Content Welcome Guest! Please Register or Login Sat April 21, 2018, 9:14 pm
AZBMW Forums › Model Specific Discussion › ///M Cars › chasing codes around
gt489
PostPosted: Tue Oct 02, 2012 12:29 pm
Post subject: chasing codes around
ive been trying to get this check light problem solved. i have a 98 m3 sedan. i was getting p1188 and p1189 codes and now i have a p0121 code and the other 2 codes have gone away. asc light comes on and the car has a flat spot at very low throttle. checked all of the vacuum lines and other known problem areas. mods are as follows. dinan tb, dinan cai, dinan exhaust. thanks in advance
current rides 01 integra type-r, 98 m3 sedan, 96 integra gs-r
kptaylor
PostPosted: Tue Oct 02, 2012 12:52 pm
Post subject: Re: chasing codes around
www.permoveo.ltd.uk/ta...fault.aspx
gt489
PostPosted: Tue Oct 02, 2012 1:06 pm
thanks. still chasing around codes though
PostPosted: Tue Oct 02, 2012 1:13 pm
I guess you expected we would go on that chase with you? I opened this thread and saw codes with no descriptions and promptly closed it. Why would we do all the work for you?
So you've identified what the codes mean?
Have you done searches for what the codes mean and what the rest of the world has done to address them?
How about bimmerforums? Their membership is tremendous and the depth of knowledge and documentation is (subjectively) better.
Have you made any changes or tested any equipment?
gt489
PostPosted: Tue Oct 02, 2012 3:22 pm
thanks for the smart ass reply. if you opened the thread then closed it why are you back in here? ive done the research one all the codes and from what people seem to do is just throw parts at it. im not spending my money like that.
P0121= Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem
P1188 = Fuel control, bank-1, sensor-1 (cylinders 1-3, pre-cat O2 sensor)
P1189 = Fuel control, bank-2, sensor-1 (cylinders 4-6, pre-cat O2 sensor)
kptaylor
PostPosted: Tue Oct 02, 2012 4:29 pm
What he's asking you is if the above link says it's more than likely the throttle position sensor, then have you tested or replaced yours? We're not mind readers...
If you've "done all of the research", then you must know what's wrong with it. Sorry for trying to help you out.
PostPosted: Tue Oct 02, 2012 4:32 pm
:popcorn
gt489
PostPosted: Tue Oct 02, 2012 4:48 pm
all i was trying to ask for was some ideas. maybe i could have explained my problem a little better but ive done all the thing ive been ready on other forums and it testing ok.
PostPosted: Tue Oct 02, 2012 5:43 pm
When did this problem develop? Have you smoked the car? How long have you had the Dinan TB on? Any tuning done with this mod? sounds like a throttle body issue that is also affecting the ASC throttle body/system.
gt489
PostPosted: Tue Oct 02, 2012 5:55 pm
this p0121 code just came up yesterday. tb has been on for a little over a month now. p1188 and p1189 codes started right before i put the tb on. the codes dont usually set the light until about 30 miles after the gas tank has been filled. sounds weird but thats when it usually happens
PostPosted: Tue Oct 02, 2012 8:08 pm
go back to stock. leave it there. problem solved.
gt489
PostPosted: Mon Oct 15, 2012 12:05 pm
so the codes p1188 and p1189 came back. ive checked everything from the maf bacf for leaks and couldnt find any. only throws the code about 30mile after filling the gas tank
kptaylor
PostPosted: Mon Oct 15, 2012 2:11 pm
1188 & 1189 are O2 sensor(s), usually. YMMV.
gt489
PostPosted: Mon Oct 15, 2012 2:15 pm
YMMV? i have changed the tb back to the stock one and cleared the codes. should i do a battery reset?
kptaylor
PostPosted: Tue Oct 16, 2012 12:57 pm
YMMV = Your mileage may vary.
Those codes usually mean your O2 sensor(s) are bad. Key word is "usually".
