Toggle Content Welcome Guest! Please Register or Login Sat April 21, 2018, 9:46 pm
AZBMW Forums › Model Specific Discussion › 1-4 Series › Small update
Small update
Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
scottinQC
PostPosted: Sat Oct 06, 2012 6:37 am
Post subject: Re: Small update
adjust the belt. chances of breaking the belt are higher than wearing bearings. neither is good, but a busted belt is worse.....
PostPosted: Mon Oct 22, 2012 9:25 pm
well continuing in the spirit of the never ending problem list, i decided to chase down my idle issue a bit more.
This time i went after the coolant-operated air-slide valve (why they designed this i will never know).
I knew my WUR is in working order and when i would squeeze the vacuum hose coming from the valve to the intake manifold, the idle would drop. Bingo. so i took it out.
it looked a little haggard
this is what it looked like when cold. it works the same way as the electric ones do, allowing more metered air to the engine while cold to help the idle stay up.
This the port where the vacuum hoses attach. As you can see, its wide open when cold.
And this is where the coolant hoses go. I have yet to determine the direction of flow but i know one coolant hose goes from the valve, makes a 90deg turn straight into the block. The other hose goes to the bottom section of what the WUR mounts to. And another hose goes from the WUR up to the thermostat housing. Interesting i know.
Close up view. Made in West Germany. Thats how you know its good.
So decided to test it to see if it even worked. It does, but it doesnt close all the way. Still trying to determine if this is normal.
Also replaced both of the old coolant and vacuum hoses.
Thats it for now.
PostPosted: Wed Oct 24, 2012 5:18 pm
I got tired of looking at a coolant bottle that looks all lopsided and would fall off its mounts at any point in time. So...
I cut off the previous horribly executed mounts and made my own. By that i mean i went through my scrap bin and found some angled bits of metal and welded them on.
Be easy on my welds, im still a novice beginner.
Then decided the easiest way of attaching the coolant bottle was to weld some cap screws to the mounts so i didnt have to fiddle with trying to hold a bolt and a nut while attaching/detaching.
one side has a metal spacer welded in also to give a little more height to the front.
yes i used flux-core.
and here it is sittin pretty.
PostPosted: Wed Oct 24, 2012 5:37 pm
lol, your novice welds suck. A+ for effort and ingenuity though!
For the record, I can't even solder....
PostPosted: Thu Oct 25, 2012 2:40 am
Haha yeah thanks. They look alot better than some of my earlier stuff though.
I cant believe you cant solder. After all the work done to your car, you expect me to believe that?
scottinQC
PostPosted: Thu Oct 25, 2012 5:20 am
play with your wire speed a bit. seems to have been popping and sputtering when you were welding. A touch faster would yield better results.
PostPosted: Thu Oct 25, 2012 12:11 pm
It's true, actually.
I am quite adamant about using good connectors AND shrink tube. Now that I set up an actual work bench in the garage I will practice my soldering skills.
I would love to learn to weld, that my friend is a true skill-set when working on older cars.
sterling
Is fassssst!
PostPosted: Thu Oct 25, 2012 2:29 pm
giantkeeper wrote:
I would love to learn to weld, that my friend is a true art-form when working on older cars.
Fixed.
PostPosted: Thu Oct 25, 2012 3:44 pm
Art form is right. My father works for a welding company and does it all day long. I asked him for some pointers and he said after all this time he still doesnt quite have it down and isnt worthy of giving advice. Fucker.
PostPosted: Thu Oct 25, 2012 3:47 pm
Ima have to use that line.
"Can you look at this E28 for me or at least tell me what to look for?"
"After all this time, I still don't know much about these cars, so I'm not worthy of giving advice."
I like it.
JAGER
PostPosted: Thu Oct 25, 2012 4:09 pm
You should practice welding on that RV in the front of your place Gabe!
PostPosted: Thu Oct 25, 2012 4:15 pm
That's how I know where Gabe lives. I see the RV from the airplane.
vdubvance
PostPosted: Mon Nov 12, 2012 7:21 pm
I'm always happy to lend advice.
Disclaimer: Use at own discretion.
Looks great bastard! Damn, I woulda killed for those recaros!
PostPosted: Tue Nov 20, 2012 11:32 pm
Well i havnt driven it for a while because it just doesnt like the cold and im tired of chasing vacuum leaks. But i finally got my act together and some spare time and decided to check a couple things over.
I discovered my injector seals are just worn the fuck out. One of my injectors wasnt actually seated in the port. I ordered new seals but decided i couldnt wait, i needed it back on the road.
The injectors were a lot easier than i thought to remove. Just a nice little tug with a pry bar and pop goes the weasel.
The injectors themselves were in tiptop shape, but those seals....
It was getting late at this point so i just wanted to get it done and not worry about taking pictures.
But long story short, i cleaned everything up, including the ports themselves by shoving paper towels in the holes and soaking them with carb cleaner, it works really well.
I eventually re-installed the old seals with something i was just taking a chance on, Teflon Tape! and you know what? it works. Car likes the cold now
Next issue: i discovered the source of my high idle, for real this time. stay tuned.
PostPosted: Tue Nov 20, 2012 11:49 pm
Good job big red, good job!
Page 5 of 7
