View previous topic :: View next topic |
Author |
Message |
4DR3N4L1N3 Banned
Offline Joined: Mar 23, 2012 Posts: 255
Posted: Sat Apr 07, 2012 10:49 pm Post subject: Re: 95 M3 turbo build |
and id like to ride in it! lol
_________________ 1993 BMW 325i E36 4 door - sport seats. LOVING THEM!
1996 Toyota Tercel - 53.03mpg highway so DGAF
Back to top |
Somy Cone Killer
Offline Joined: Mar 13, 2011 Posts: 621
Posted: Wed Apr 11, 2012 3:17 pm Post subject: Re: 95 M3 turbo build |
4DR3N4L1N3 wrote: |
and id like to ride in it! lol |
Hoping to have everything done end of April
_________________ ACS M3
Back to top |
4DR3N4L1N3 Banned
Posted: Wed Apr 11, 2012 8:00 pm Post subject: Re: 95 M3 turbo build |
Just hit me on FB or here when you need a hand, I should be generally open. I am expecting a call tomorrow for a job interview though, so my time may get scarce, but sleep sucks anyway lol
Back to top |
Somy Cone Killer
Posted: Thu May 10, 2012 12:53 pm Post subject: Re: 95 M3 turbo build |
Ok.gentlemen, 300 miles till the clutch is all broken in.
Please post a dyno place recommendations. I want to go next saturday.
Places i know are good speed and evoms. I think evoms dyno only for their cars and i hear a lot pf rumors about good speed both good and bad.
Ideas??
Back to top |
Mpoweraz WorldTouringChamp
Offline Joined: Jan 08, 2007 Posts: 1007
Posted: Thu May 10, 2012 2:01 pm Post subject: Re: 95 M3 turbo build |
good speed in scottsdale. right near the costco off of raintree/101. supposed to have a stupid accurate dyno.
Back to top |
Somy Cone Killer
Posted: Thu May 10, 2012 2:05 pm Post subject: Re: 95 M3 turbo build |
Mpoweraz wrote: |
good speed in scottsdale. right near the costco off of raintree/101. supposed to have a stupid accurate dyno. |
I keep hearing that and some say the dyno is not dialed in correctly. I also would like to see whp not bhp if possible.
Any others??
Back to top |
hobbit382 Newbie
Offline Joined: Sep 01, 2007 Posts: 108
Posted: Thu May 10, 2012 4:10 pm Post subject: Re: 95 M3 turbo build |
I vote good speed.
Back to top |
Mtrace Lord of the flywheels
Offline Joined: Jul 17, 2008 Posts: 1012 Location: Gilbert
Posted: Thu May 10, 2012 4:18 pm Post subject: Re: 95 M3 turbo build |
I vote goodspeed as well, since its your first dyno, your only looking for AFR and boost for Bret to tune from. Your whp probably wont be what your expecting, although I would expect around 450.
Back to top |
Somy Cone Killer
Posted: Fri May 11, 2012 12:31 am Post subject: Re: 95 M3 turbo build |
Good speed cant do saturday and i cant do weekdays. They want $95 bucks. Dang really?
He said 50 if i have my bmw cca card which i dont. 200 miles till clutch all broken in, getting close
Back to top |
Somy Cone Killer
Posted: Fri Jun 22, 2012 2:14 pm Post subject: Re: 95 M3 turbo build |
Had an oil leak. Oil feed wasn't looking too good so I changed/rerouted with another. Went for a small test drive. Few minutes after I parked I saw every drop of coolant on the street.
Head gasket? I saw on forums that sometimes one of the hoses under the intake manifold leak or break if they are old. Anyone had this happen to them??
Back to top |
AZE46M3 Newbie
Offline Joined: Jul 16, 2009 Posts: 75
Posted: Fri Jun 22, 2012 2:34 pm Post subject: Re: 95 M3 turbo build |
If you blew a head gasket the coolant will get into the oil. If you're seeing coolant all over the ground the most likely explanation is that you broke a coolant line somewhere.
In some cases boost will lift the head and cause combustion gas to push coolant out of the motor. I don't think this is your problem because you don't lose all of your coolant and the coolant loss happens pretty much right after you close the throttle.
Check your coolant lines, I'd be willing to bet you find the leak.
Back to top |
Somy Cone Killer
Posted: Fri Jun 22, 2012 4:19 pm Post subject: Re: 95 M3 turbo build |
AZE46M3 wrote: |
Check your coolant lines, I'd be willing to bet you find the leak. |
Yeah I am doing that as soon as I get home. I really hope its a cheap fix
Back to top |
AZE46M3 Newbie
Posted: Fri Jun 22, 2012 4:34 pm Post subject: Re: 95 M3 turbo build |
When you dump a bunch of coolant at once it's almost always a broken line or a loose clamp. I'm pretty confident you'll find the problem when you inspect the lines.
Back to top |
Somy Cone Killer
Posted: Sat Jun 23, 2012 11:12 pm Post subject: Re: 95 M3 turbo build |
It was a combination of a leaking hose and gasket. had to take manifold and many things off to get to it but i am happy its not a HG
thanks for your help
Back to top |
AZE46M3 Newbie
Posted: Sun Jun 24, 2012 3:00 pm Post subject: Re: 95 M3 turbo build |
Glad to hear you got it solved and it wasn't a head gasket.
Back to top |
