Toggle Content Welcome Guest! Please Register or Login Sun May 27, 2018, 1:59 pm
AZBMW Forums › Model Specific Discussion › 5-8 Series › E34 tantrum
E34 tantrum
Deutschermann
PostPosted: Mon Sep 12, 2011 2:55 am
Post subject: E34 tantrum
So my E34 is throwing a tantrum, she doesnt want to start (just cranks over, over, and over) like 1 minute later she decides to start. I was wondering if anyone else had a similar problem and if any of you could hint me twards a solution. Thanks!
E34 freak!
GatoEnFuego
PostPosted: Mon Sep 12, 2011 11:17 am
Post subject: Re: E34 tantrum
check fuel pressure. check spark. check for compression.
87 E30 325 - M50 swapped
90 E32 735il - Stock
PostPosted: Mon Sep 12, 2011 11:40 am
The car was hoping you'd give up and leave the keys and title on the seat after 45 seconds.
Previous response should get you on the right track.
jfj707
PostPosted: Tue Sep 13, 2011 1:09 am
Any progress today? I would start by checking fuel too.
'95 525i black/black 5-speed - Bilsteins - winter package - keyless - 206K
'93 525iT - Islandgrun/Parchment - Bilsteins and Vogtlands - SLS Delete - Functioning Dbl Sunroof - 202K
Deutschermann
PostPosted: Wed Sep 14, 2011 12:46 am
ive checked spark, and compression (all good) ive figured out that if i wait about a min with the key turned to the ACC position (just before cranking) it will start up within a second.
E34 freak!
GatoEnFuego
PostPosted: Wed Sep 14, 2011 2:06 am
fuel filter and/or fuel pump. check pressure and if it continues to climb while the key is on and the pump has stopped running it probably means the filter is clogged. if it's slow to build pressure that means the pump is more than likely tired, is it making any funny noises?
BK544E34
PostPosted: Wed Sep 14, 2011 4:51 am
+1.
I've also noticed a low battery will effect the fuel pump, as well.
[1994 544i][1999 Z3 M Coupe][MK3 VR6 Jetta]
Enjoying the not-so-120 degree summer!
Deutschermann
PostPosted: Fri Sep 16, 2011 5:14 am
well i just changed the fuel filter (needed to be changed anyway) but i believe its slow to build pressure. :/ good thing i still have the fuel pump from the wrecked car Very Happy
E34 freak!
Deutschermann
PostPosted: Fri Sep 16, 2011 5:15 am
BK544E34 wrote:
+1.
Battery is brand new. guess its the pump then
E34 freak!
