Toggle Content Welcome Guest! Please Register or Login Sun May 27, 2018, 1:54 pm
AZBMW Forums › Model Specific Discussion › 5-8 Series › E28 battery charging question
uter
PostPosted: Thu Sep 08, 2011 1:19 pm
Post subject: E28 battery charging question
(Standard Noobie Disclaimer...)
Does the e28 have a positive battery terminal site like newer BMWs?
I'd like to hook up my Schumacher XC75 battery charger and I wasn't able to spot a site for the positive cable other than the battery terminal itself. The negative, I assume, goes to the ground/engine lift bracket.
Alas, I haven't bought at Bentley manual and my old Chilton manual isn't specific enough about the e28.
1990 325ic
1995 840Ci
2014 i3
2016 X5 40e
aaronfnfranklin
PostPosted: Fri Sep 09, 2011 1:38 am
Post subject: Re: E28 battery charging question
You can just put positive cable to positive post and negative cable to negative post when using a battery charger. Just remember that negative should always come off first and be put on last.
PostPosted: Sat Sep 10, 2011 4:23 am
Since the battery is mounted in the front of the car, you connect straight to the battery. Good luck!
uter
PostPosted: Mon Sep 12, 2011 1:22 am
gracias!
1990 325ic
1995 840Ci
2014 i3
2016 X5 40e
