Toggle Content Welcome Guest! Please Register or Login Thu January 18, 2018, 4:10 am
wtb: open 3.25, 3.46, 3.73 diff
Last post by bullfrog in Classifieds/Wanted on Jul 21, 2017 at 00:33:57
Looking for an E36 M3 - 5 speed
Last post by ambition in General Discussion on Jul 02, 2017 at 02:50:51
WTB BMW E21 back seat
Last post by meeceboy78 in Classifieds/Wanted on Jun 12, 2017 at 19:50:33
AZBMW Forums › Model Specific Discussion › 1-4 Series › Could someone with a 93-95 325i/is do me a favor?
All things 1, 2, 3 and 4 series
Post new topic    Reply to topic    Printer Friendly Page     Forum Index ›  1-4 Series
johnlemonx
PostPosted: Tue Nov 18, 2014 11:02 pm
Post subject: Could someone with a 93-95 325i/is do me a favor?
The 93 325is I just bought just failed the emissions test by a lot. Check engine light is on, code is 1215 (MAF sensor). I tested the MAF with my DMM: 14 volts going in and ~8.7-8.9 output volts at the connector at idle which I am hoping is high. The voltage falls a bit when I open the throttle. All wires going to the DME are fine, X6454 ground is fine as well.
So can someone with a 93-95 325i/iS check their working MAF and put up the output voltage here please, I am really hoping that it is my MAF that is bad.
These are the two pins to test:
1989 525i 193k bronzitbeige metallic
1993 325is Brilliantrot
S52limo
PostPosted: Wed Nov 19, 2014 12:06 am
Post subject: Re: Could someone with a 93-95 325i/is do me a favor?
This should help you out.
View user's profile Visit poster's website AIM Address
johnlemonx
PostPosted: Wed Nov 19, 2014 12:24 am
that is for the 1992 only 6 pin MAF with DME m3.1, no?
Mine has M3.3.1 w/ a four pin MAF, do these numbers still apply?
S52limo
PostPosted: Wed Nov 19, 2014 12:33 am
Yes. This covers 3.1 through 3.3.1
johnlemonx
PostPosted: Wed Nov 19, 2014 12:43 am
ok, so which is the correct resistance value between the 2 pins in my maf?
3-4 ohms or 16.3 ohms
S52limo
PostPosted: Wed Nov 19, 2014 12:59 am
Good question. The shop manual does not elaborate any further but says this applies to the 3.3.1.
laplana325i
PostPosted: Wed Nov 19, 2014 3:09 am
can you post your emission numbers
johnlemonx
PostPosted: Wed Nov 19, 2014 3:30 am
laplana325i
PostPosted: Wed Nov 19, 2014 2:38 pm
If the engine runs fine then those numbers indicate bad catalytic converter.
johnlemonx
PostPosted: Wed Nov 19, 2014 3:16 pm
Well the engine is running in limp mode because when I disconnect the maf there is no change in the idle, I'm going to try a different maf and see if it passes or at least see if the numbers drop a bit.
johnlemonx
PostPosted: Wed Nov 19, 2014 10:36 pm
Good news! Pulled a used maf from Glendale Auto Parts, installed it and no more check engine light. ~0.759 volts at idle. Old maf was putting out 8v more than it should have.
