Toggle Content Welcome Guest! Please Register or Login Sat June 23, 2018, 10:12 am
AZBMW Forums › Model Specific Discussion › 1-4 Series › Wonky Sunroof issue, need help.
All things 1, 2, 3 and 4 series
Post new topic    Reply to topic    Printer Friendly Page     Forum Index ›  1-4 Series
ESpeedy
PostPosted: Tue Apr 15, 2014 8:54 pm
Post subject: Wonky Sunroof issue, need help.
Tried to do the tilt open on the sunroof yesterday. Pushed button, roof tilted, but then immediately shut again. It operates normally when I pull back on the switch to open it fully but won't stay open when I try to have it tilt. Any help is appreciated.
View user's profile Send e-mail
PostPosted: Tue Apr 15, 2014 9:29 pm
Post subject: Re: Wonky Sunroof issue, need help.
Just for S&G's what year and series are we referring to?
ESpeedy
PostPosted: Tue Apr 15, 2014 9:30 pm
'01, 330 Xi, Sedan.
PostPosted: Wed Apr 16, 2014 11:46 am
I did a google search and came up with 5000+ hits on Sunroof issues for E46 and E39's. It may be best to check some of those yourself since you know more of the symptoms and issues than we do. The lift arms sound as if they could be the issue.
335iAdam
PostPosted: Wed Apr 16, 2014 12:18 pm
I would start with a reinitialization and see if it still does the same thing (hold the tilt button up for about 20 seconds. If it goes up and then immediately back down like usual then I would suggest trying to initialize it in INPA).
Same thing happened to my wife's X5 35d, except with the roof stuck in the tilt position, and I was not able to reinitialize with the button but INPA did the trick. Have not had an issue since.
That is where I would start because there are about 35,000 things it could be (tilt sensor, anti-pinch mechanism, sliders, alignment, rails, lift arms etc).
BMWCCA Member
ESpeedy
PostPosted: Mon Apr 21, 2014 7:57 pm
I tried the 20 second hold down trick and it didn't work. So I guess that means a visit to the stealership becuz INPA. Thanks for the suggestion.
